PROBLEM
Note: The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
Attempting to download a web map containing ArcGIS Server feature services for offline use with Collector for ArcGIS fails, and returns the error message:
Error: The operation couldn't be completed. Error in obtaining version for Sync.
or
Error: The map 'Map_Name' failed to download with the message: Error in obtaining version for Sync.
The following entry is found in the server logs:
{"code":500,"description":"Error in obtaining version for Sync."} Failed to execute (Create Feature Service Replica).
When users download a web map containing versioned data for offline use, the Create Replica call is used to create a local copy of the data with a version name. By design, the version name of the replica also includes the user name of the user (editor) who downloads the web map.
Although the documented limit for version names is 64 characters, in ArcGIS 10.3.1 for Server, this error occurs because the version name exceeds 30 characters in length due to the user name being too long. This is a known limitation, and is logged as BUG-000090931. For more information, refer to ArcGIS for Desktop Help: System tables in a geodatabase - SDE_versions.
Use one of the workarounds provided below to solve this issue.
Article ID: 000013804
Get help from ArcGIS experts
Start chatting now
