PROBLEM
Water Utility Network and Attribute Assistant toolbars showing up "Missing".
Last Published: June 22, 2023
When trying to enable the Attribute Assistant, Water Utility Network Editing, and Reporting toolbars in ArcMap, their buttons show up with a "Missing" message, as shown in the image below:
missing buttons inn toolbar
Cause
The Water Utility Network and Attribute Assistant add-ins are not properly configured.
Solution or Workaround
  1. Ensure that theĀ Water Utility Network and Attribute Assistant add-in files (.esriAddIn) have been added to the appropriate folder in C:\Program Files (x86)\ArcGIS\Desktop10.X\bin\Addins. If needed, these files can simply be copied and pasted to this location.
  1. Open ArcMap and click on the Customize tab > Add-In Manager, and if the add-ins are in the My Add-Ins section, delete them so they will be shown in the Shared Add-InsĀ section, as shown in the following image.
Article ID: 000030379
Software:
  • ArcGIS for Water Utilities
  • ArcGIS Desktop
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
