ERROR
When converting multiple datasets with similar names (mydata_polyline, mydata_polyline_1), the first dataset is converted, then warning message occurs and subsequent datasets are not converted.
If the names are the same, except for the numeric suffix, both outputs may be assigned the same default name. The first conversion will be successful, but the second will fail since the output name is already in use.
Make each of the output names in the batch grid unique.
Article ID:000003106
Get help from ArcGIS experts
Download the Esri Support App
