PROBLEM
Voxel layers referencing a netCDF file and an SLPK or service show different unique value counts in ArcGIS Pro
First Published: November 6, 2023
Last Published: November 6, 2023
In ArcGIS Pro 3.2, a new feature is added for voxel layers that displays the unique value counts of a discrete variable in the Symbology pane. The unique value counts show different values when comparing the voxel layer referencing from a netCDF file and from an SLPK or a service created in a version prior to ArcGIS Pro 3.2. The voxel layer referencing a netCDF file shows the correct counts.
Cause
The SLPK and services created from previous versions have the incorrect unique value counts.
Solution or Workaround
To resolve the issue, the SLPK or services must be re-created or republished using ArcGIS Pro 3.2 version. Use theĀ Create Voxel Scene Layer Content tool to create a new voxel scene layer package.
Article ID: 000031304
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
