BUG
VMWare Tools 11.1 and later causes ArcPy to fail
Last Published: March 26, 2021
ArcPy fails on VMs using VMWare Tools 11.1 and later.
Cause
The SVGA Driver installed with VMWare Tools 11.1 and later versions causes ArcPy to stop responding.
VMWare Tools setup, SVGA selected
Both VMWare and Esri are aware of the issue and are working towards a permanent solution.
Workaround
Use an earlier version of the SVGA Driver. If upgrading from an earlier version of VMWare Tools, opt not to install the driver:
VMWare Tools setup, SVGA Driver not selected
Otherwise, revert to version 11.0.6 and then upgrade, again choosing not to install the SVGA Driver.
Article ID: 000025320
Software:
  • Third Party Product
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
