HOW TO
View a map-enabled report with drill-up and drill-down capabilities in PDF format
First Published: May 5, 2016
Summary
To view a map-enabled report with drill-up and drill-down capabilities in PDF format, an administrative setting must first be enabled. By setting preserveDrillContextPDF to true, the drill action is preserved when viewing a map-enabled report in PDF.
Procedure
Before following the steps below, it is recommended that the Esri Maps for IBM Cognos administrator make a backup of the following file.
Windows:
<em4c_location>\webcontent\esrimap\configuration\settings.js
Unix:
<em4c_location>/webcontent/esrimap/configuration/settings.js
  1. On the EM4C Gateway(s), open the settings.js file in a text editor.
  2. Set preserveDrillContextPDF to true as follows:
     preserveDrillContextPDF: true
    define({
    arcgisUrl : "https://myorganization.arcgis.com",
    arcgisAuthType : "user",
    arcgisAppUser : "",
    arcgisAppPassword : "",
    arcgisAppId : "myappid",
    arcgisSharing : true,
    corsEnabledServers : [],
    selectionColor : "#FF0000",
    infographicsEnabled : true,
    docRoot : "https://doc.arcgis.com/{LOCALE}/maps-for-cognos/", // or "installed"
    preserveDrillContextPDF : true
  3. Save the changes to settings.js.
  4. Refresh the browser cache.
Article ID: 000012225
Software:
  • ArcGIS Maps for IBM Cognos
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
