Frequently asked question
Version Management Service - ArcGIS Advanced Editing user type extension requirements
Last Published: October 10, 2025
The ArcGIS Advanced Editing user type extension was introduced with ArcGIS Enterprise 11.2. For branch versioned data, it is required for many Version Management Service REST API operations when working with web feature layers that are from feature services with the version management capability enabled. When working with web feature layers, this requirement also impacts workflows in ArcGIS Pro.
Starting at ArcGIS Enterprise 12.0, licensing changes were made to no longer require the ArcGIS Advanced Editing user type extension for the following:
  • Operations to create, alter, and delete versions
  • Operations to support editing within a version
For organizations with ArcGIS Enterprise 11.3 or 11.5, review and install the following patch to update licensing to current levels: ArcGIS Server Branch Versioning Licensing Patch
Version Management Service - REST API operations
The table below outlines the ArcGIS Enterprise versions and Version Management service operation that require organization members to be assigned the ArcGIS Advanced Editing user type extension.
Table key:
🔑 Requires ArcGIS Advanced Editing user type extension
*  Patch available - There is no requirement for ArcGIS Advanced Editing user type extension with the ArcGIS Server Branch Versioning Licensing Patch applied
-  Endpoint not available at this release
Operation11.211.311.411.512.0 and later
Create🔑*🔑🔑*
Delete🔑
Alter🔑
Start Editing🔑*🔑🔑*
Stop Editing🔑*🔑🔑*
Delete Forward Edits🔑*🔑🔑*
Purge Lock🔑
Conflicts🔑
Differences🔑
Inspect Conflicts🔑
Partial Post---🔑🔑
Post🔑
Reconcile🔑
Restore Rows🔑
Article ID: 000037734
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
