HOW TO
using Python to Extract slpk file to an s3 bucket
Last Published: October 2, 2024
Summary
It may sometimes be advantageous to automate the process of extracting an Esri Scene Layer Package (SLPK) to an AWS S3 bucket and do all the work using Python, as opposed to doing it from the command line or ArcGIS Pro. The script below can also be run using the Windows Task Scheduler.
Procedure
The following Python script can be used to extract an SLPK to an S3 bucket. The assumption is that there is an .acs connection file already created.  In this example, since the Python script, the .acs file and the .slpk are within the same directory, there is no need to specify the file path.
import arcpy
import os
os.getcwd()
dir = os.path.dirname(__file__)
def main():
  acs_connection = os.path.join(dir,"test.acs")
  slpk_file = os.path.join(dir,"testpackage.slpk")
  arcpy.management.ExtractPackage(
    in_package=slpk_file,
    output_folder=None,
    cache_package="CACHE",
    storage_format_type="COMPACT",
    create_ready_to_serve_format="EXTRACTED_PACKAGE",
    target_cloud_connection=acs_connection
arcpy.AddMessage("succeeded")
if __name__ == "__main__":
    main()
The output can be seen within the S3 bucket by using the .acs file within ArcGIS Pro by adding a Cloud storage connection.
Article ID: 000032316
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
