PROBLEM
When using the Oracle import utility to append data to existing tables, Oracle reports the following warning:
"Note: table contains ROWID column, values may be obsolete".
The following example demonstrates using the Oracle import utility to import the build.exp file with the ignore equals yes option. The ignore option instructs Oracle to ignore the existence of the object and append the rows from the export file to the existing table.
Code:
D:\> imp tb/password file=build.exp tables=(building) ignore=y
. importing TB's objects into TB
. . importing table "BUILDING" 13 rows imported
. . importing table "S158_IDX$"
Note: table contains ROWID column, values may be obsolete 21 rows imported
Import terminated successfully without warnings.
The cause of the problem is the Oracle import utility. The import should not be importing/appending rows to a domain index (st_spatial_index), because the creation of the rows in the table generates the entries in the index.
If the import with spatial index has already been done, then re-creating/rebuilding the spatial index fixes the problem.
Article ID:000009818
Get help from ArcGIS experts
Download the Esri Support App
