BUG
An issue has been found that impacts feature service layers in ArcGIS Pro 1.0.
When using the Field Calculator to calculate a field against a web feature layer (layer or table from a feature service), the fields that are not updated by the Field Calculator are set to NULL.
This only applies when working directly against the feature service. If working directly against other data sources such as a file geodatabase, an enterprise geodatabase, or shapefiles, this issue does not occur.
At most, the number of rows affected by this issue is the number specified by the 'MaxRecordCount' property in the connected portal or server. This is set to 1000 rows by default.
Managed fields (such as OID, GlobalID, or editor tracking fields) are not affected by this issue.
This is a known issue: BUG-000086874.
Esri has provided a fix for this issue in the 1.0.2 update to ArcGIS Pro. The next time ArcGIS Pro is opened, accept the prompt to download and install this update. If you have disabled ArcGIS Pro from checking for updates, please visit my.esri.com to download the latest updates for ArcGIS Pro.
For more information, visit the following link about applying ArcGIS Pro software updates.
Article ID: 000012465
Get help from ArcGIS experts
Download the Esri Support App
