BUG
Using ArcGIS Server (Java) on a machine with a hyphen in its hostname, parameters for geoprocessing tasks in web applications are hidden
In ArcGIS Server for JAVA, after configuring a Web application with a geoprocessing task using the ADF for ArcGIS Server for JAVA, the input parameters for the geoprocessing task are blank.
[O-Image]
Cause
The machine on which ArcGIS Server for Java is installed has a hyphen in the hostname.
Workaround
Rename the machine on which ArcGIS Server for Java is installed to a hostname that does not include a hyphen.
    Article ID: 000010709
    Software:
    • ArcGIS Server
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
