ERROR
Attempts to create, open, and run notebooks or notebook tasks in ArcGIS Notebooks in ArcGIS Online fail, and return the following error message:
Error: User <user_name> in credit budgeting enabled org <org_ID> with subscription type '<subscription_type>' has <credit_value> credits which is fewer than min credits check of 30
Credit budgeting is enabled for the organization, and the member does not have sufficient credits to utilize notebooks. Creating, opening, and running notebooks require 30 credits per hour, per notebook, using the Advanced runtime as well as the Advanced with GPU runtime. Scheduled tasks will also fail with this error for all notebook runtimes. Refer to ArcGIS Online: Credits by capability for more information.
To resolve the issue, choose one of the workarounds provided.
Update the member's credit allocation
Reset the member's credit allocation in Set allocation to be more than 30, or select No allocated limit in the Set credit allocation window. Refer to ArcGIS Online: Manage credit budget for instructions and more information.
Disable credit budgeting for the organization
Disable credit budgeting for the organization to remove individual credit limits. Refer to ArcGIS Online: Disable credit budgeting tools for instructions.
Note: If necessary, contact Esri Customer Service to purchase additional credits for the organization. Refer to ArcGIS Online: Get more credits for more information.
Article ID: 000027230
Get help from ArcGIS experts
Start chatting now
