HOW TO
Use Trimble Mobile Manager as a mock location provider with ArcGIS Field Maps (Android)
First Published: March 26, 2026
Last Published: March 26, 2026
Summary
This article describes a temporary workaround to bypass connection issues when using an external Trimble GPS antenna with ArcGIS Field Maps on Android devices. Such connection issues include:
This workaround, recommended by Trimble Support, uses Android Mock Locations to pass high-accuracy GPS coordinates from Trimble Mobile Manager (TMM) to Field Maps through the device’s integrated location provider.
Cause
This approach may be useful when direct Trimble Mobile Manager integration with Field Maps is unavailable or unreliable due to device Android version or device manufacturer.
Procedure
  1. Set Trimble Mobile Manager as the mock location provider. Refer to Trimble: Android location services for more information.
  2. Configure the location provider in ArcGIS Field Maps.
    1. In ArcGIS Field Maps, tap your user icon The user icon at the top left of the screen to open the Profile screen.
    2. Under Location, tap Provider.
    3. Select Integrated. Do not select a Trimble provider.
  3. On your Android device, launch Trimble Mobile Manager.
    1. Confirm connection to the external GNSS receiver.
    2. Verify that accurate coordinates are being reported.
  4. Use Field Maps normally for data collection.
Field Maps receives location data via Android’s integrated location services, which are overridden by Trimble Mobile Manager injecting GNSS coordinates into the Android operating system using Mock Location. ArcGIS Field Maps then consumes this data as if it were coming from the device’s internal GPS.
Verify Mock Location settings after Android OS updates.
This workflow should be treated as a temporary workaround. Contact Esri Technical Support for additional assistance.
Article ID: 000039844
Software:
  • ArcGIS Field Maps Android
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
