HOW TO
Use the signIn URL parameter to a survey in the Survey123 web app for Portal for ArcGIS
First Published: December 16, 2025
Last Published: June 26, 2026
Summary
The signIn URL parameter shows the sign-in button or requires users to sign in for public surveys. Public surveys can include features that would only work when users are signed in.
For survey forms hosted in Portal for ArcGIS, the valid value used is ‘require’ which allows the users to sign in by redirecting to the sign-in page and provide a convenient login experience in the browser.
Procedure
  1. Create a survey form hosted in the Portal for ArcGIS with the URL consisting of:
https://survey123.arcgis.com/share/c15325132c544cb790c58f4273c3b520?portalUrl=https://organization.domian.com/webadaptorinstancename
  1. Add the &signIn=require URL parameter as shown in the following example to redirect to the sign-in page of the Portal for ArcGIS:
https://survey123.arcgis.com/share/c15325132c544cb790c58f4273c3b520?portalUrl=https://organization.domain.com/webadaptorinstancename &signIn=require
• In contrast to ArcGIS Online where we utilize the parameter in the format
"https://survey123.arcgis.com/share/36ff9e8c13e042a58cfce4ad87f55d19?signIn=require," when working with Portal for ArcGIS, we should use the ‘&’ symbol (ampersand). This is necessary because we already employ the parameter ?portalURL to indicate that the survey is hosted within the portal. • Each next parameter must be appended by ‘&’ character.
Article ID: 000037503
Software:
  • Portal for ArcGIS
  • ArcGIS Survey123 Field App iOS
  • ArcGIS Survey123 Field App Android
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
