HOW TO
The arcpy.CreateUniqueName data function creates a unique output name by adding integers to the output name. This helps avoid errors or unintentionally overwriting existing datasets. The return format of the data function includes the full path name, and some geoprocessing tools require that an output location and an output name are specified in separate parameters. The Feature Class to Feature Class geoprocessing tool is one example of this. In these instances, the unique name must be used without the full path name, and this can be done with Python.
Code:
#import arcpy and the OS module
import arcpy, os
from arcpy import env
#set workspace parameter
ws = env.workspace = r"C:\Temp\scratch.gdb"
#set input/output variables
inFeatures = "Customers"
outOriginal = "CustomerLocations"
#create unique name
unique_name = arcpy.CreateUniqueName(outOriginal)
#grab the basename of the full path returned
outName = os.path.basename(unique_name)
#pass outName into Feature Class to Feature Class
arcpy.FeatureClassToFeatureClass_conversion(inFeatures, ws, outName)
Article ID: 000011813
Get help from ArcGIS experts
Start chatting now
