HOW TO
ArcInfo has a Frequency command that returns a list of unique code occurences and their frequency for numeric and text fields. Instructions provided illustrate how to perform this task in ArcMap using VBA and ArcObjects.
Code in the Project's ThisDocument code module only runs in the current map document. To store the code in all of the map documents, open the Normal.mxt ThisDocument code module instead.
Code:
'Set a reference to Microsoft Scripting Runtime Library
Option Explicit
Sub TestFrequency()
' Make a dictionary of key-value pairs where the key is the
' field value, and the dictionary value is the frequency count
Dim pDict As New Scripting.Dictionary
Dim pMxDoc As IMxDocument
Dim pFLayer As IFeatureLayer
Dim pFSel As IFeatureSelection
Dim pFCur As IFeatureCursor
Dim lFld As Long
Dim v As Variant
Dim pFeat As IFeature
Set pMxDoc = ThisDocument
' US Counties are in layer(0)
Set pFLayer = pMxDoc.FocusMap.Layer(0)
Set pFSel = pFLayer
If pFSel.SelectionSet.Count = 0 Then
Set pFCur = pFLayer.FeatureClass.Search(Nothing, True)
Else
pFSel.SelectionSet.Search Nothing, True, pFCur
End If
lFld = pFCur.FindField("Name")'change the name of the field here
If lFld = -1 Then
Debug.Print "field NAME not found" 'change the name of the field in the error message here
Exit Sub
End If
Set pFeat = pFCur.NextFeature
Do While Not pFeat Is Nothing
v = pFeat.Value(lFld)
If pDict.Exists(v) Then
pDict.Item(v) = pDict.Item(v) + 1
Else
pDict.Add v, 1
End If
Loop
' list all counties and their frequency
For Each v In pDict.Keys
If pDict.Item(v) >= 1 Then
Debug.Print v & ", " & pDict.Item(v)
End If
Next v
End Sub
Get help from ArcGIS experts
Download the Esri Support App
