HOW TO
Instructions provided describe how to use the Python UpdateCursor method to calculate values in a table based on another field.
Sometimes it is desirable to set attributes in a field to certain values based on the value of another field. In this case the UpdateCursor with conditional statements can be used to correctly set those values.
Code:
# Import the standard modules and create the geoprocessor...
import arcgisscripting, os, string, sys, time
gp = arcgisscripting.create()
# Set the overwrite to true...
gp.overwriteoutput = 1
# The file to be updated...
fc = r"C:\Temp\testdata.shp"
# Create the UpdateCursor Object
cur = gp.updatecursor(fc)
row = cur.next()
while row:
# Get the value of the field the calculation will be based on...
field1 = str(row.getvalue("FIELD1"))
# Conditional Statements
# if the field1 = value1, set field2 to equal NewVal1, etc...
if field1 == "Value1":
row.FIELD2 = "NewVal1"
cur.updaterow(row)
row = cur.next()
elif field1 == "Value2":
row.FIELD2 = "NewVal2"
cur.updaterow(row)
row = cur.next()
else:
row.FIELD2 = "NewVal3"
cur.updaterow(row)
row = cur.next()
del cur, row, gp
Article ID:000010171
Get help from ArcGIS experts
Download the Esri Support App
