HOW TO
Instructions provided describe how to use CONVERTIMAGE to change or edit TIFF header information. ArcMap uses the header information in a TIFF to georeference that image, and occasionally the information in the header causes problems with scale and georeference in ArcMap. Editing the header information is typically the safest way to solve such problems. This can be done by using CONVERTIMAGE at an Arc prompt to create a new TIFF.
Code:
CONVERTIMAGE input1.tif output1.bmp BMP
For specifics on the CONVERTIMAGE command, refer to ArcDoc.
If the TIFF is compressed, use the NONE option in CONVERTIMAGE to get an uncompressed TIFF before converting to a bitmap.
World files, *.tfw, *.bpw, and so forth, can be created, viewed, and edited with any text editor, such as Notepad.
Article ID:000005321
Get help from ArcGIS experts
Download the Esri Support App
