ERROR
URL should be the path to arcgisoutput directory on a machine with Business Analyst Server installed
First Published: May 5, 2016
Error Message
After executing the Upload Shapefile task in Business Analyst Server, the following error is returned: "URL should be the path to arcgisoutput directory on machine with Business Analyst Server installed."
Cause
The URL to the arcgisoutput directory may have been seen as incomplete by the Business Analyst Server if it does not include a forward slash (/) at the end of the URL.
Solution or Workaround
After replacing the incomplete URL with the complete URL, resend the request.
For example, replace "https://localhost/arcgisoutput" with "https://localhost/arcgisoutput/".
    Article ID: 000011229
    Software:
    • ArcGIS Business Analyst Enterprise
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
