BUG
Upgrade from ArcGIS Enterprise 11.5 to versions 12.0 or 12.1 fails when the Portal for ArcGIS 11.5 Security 2026 Update 1 Patch is installed on Windows
First Published: June 1, 2026
Last Published: June 4, 2026
When the Portal for ArcGIS 11.5 Security 2026 Update 1 Patch is installed in a Windows ArcGIS Enterprise 11.5 environment, upgrades to ArcGIS Enterprise 12.0 or 12.1 fail.
Cause
This behavior is a known bug, BUG-000185267: Upgrade from ArcGIS Enterprise 11.5 to versions 12.0 or 12.1 fails when the Portal for ArcGIS 11.5 Security 2026 Update 1 Patch is installed on Windows.
Workaround
If the Portal for ArcGIS 11.5 Security 2026 Update 1 Patch is installed, do not upgrade ArcGIS Enterprise 11.5 environments on Windows to versions 12.0 or 12.1 or uninstall the Portal for ArcGIS software until the corrected patch is installed.  In the Patch Notification Tool, the corrected version appears as Portal for ArcGIS Security 2026 Update 1 Patch with a release date of June 4, 2026. After installation, it is listed as Portal for ArcGIS Security 2026 Update 1 Patch D. This updated patch must be installed to replace earlier versions of this patch before upgrading ArcGIS Enterprise.
If you have questions, please contact Esri Technical Support.
Article ID: 000042062
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
