HOW TO
The recently released 2022 U.S. Business Analyst dataset is built using the updated Census 2020 administrative boundaries. These new boundaries have changed significantly at all levels, in all areas of the country, from those in Business Analyst datasets prior to 2022. Geography levels such as Counties or Block Groups, may have gained or lost area, been split into multiple polygons with new IDs, or been removed all together.
This blog from Garry Burgess provides background information on the challenges introduced by these boundary changes.
Care must be taken to ensure that your standard geography trade areas are built from the 2022 Business Analyst dataset, prior to setting it as your Business Analyst data source. You can return invalid results with the Business Analyst 2022 dataset if your standard geography trade areas were created with a previous vintage of Business Analyst data. Conversely, your 2022 standard geography trade areas should not be used for analysis with the 2021 Business Analyst dataset due to the same geometry discrepancy caused by boundary changes.
You can easily recreate your standard geography trade areas using the Generate Standard Geography Trade Areas tool.
Note: The 2022 Business Analyst dataset has only been released online. The installed version of the 2022 dataset releases in late summer of 2022. The installed dataset will not contain access to the 2021 Business Analyst dataset. However, you can retain access to the dataset by keeping it installed.
To update standard geography trade areas, follow these steps.
Set the Business Analyst data source
Run the Generate Standard Geography Trade Areas tool
Consider adding the Business Analyst dataset year to the output feature class name for easy identification.
Updating standard geography trade areas when using the new 2022 dataset for analysis ensures that the data variable values returned match the updated geometry for each ID.
Article ID: 000028008
Get help from ArcGIS experts
Download the Esri Support App
