HOW TO
Update a term license in an sde geodatabase
First Published: May 6, 2016
Last Published: October 6, 2020
Summary
Term licenses such as Education Site Licenses, Esri Developer Network (EDN) licenses, and other ArcGIS product licenses such as ArcGIS Server, are valid for a specific period of time.
Geodatabases authorized with an ArcGIS Server term license must be updated with a new authorization file when the existing one expires. Instructions provided describe the steps to update these licenses.
Procedure
Beginning in ArcGIS 10.1, a message is returned when connecting to an sde geodatabase that contains an expired license.
To update the license, do the following:
  1. Connect directly to the geodatabase as the geodatabase administrator.
    • In most geodatabases, this is the sde user. In dbo-schema geodatabases in SQL Server, it is a login that is dbo in the database.
    • For user-schema geodatabases in Oracle, update the license key in the sde geodatabase, and connect as the schema owner and update the key in the user-schema geodatabase.
  2. Specify a valid ArcGIS Server keycodes file in the Update ArcGIS Server License dialog box, and click OK to authorize.
Article ID: 000012771
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
