HOW TO
Instructions provided describe how to update NULL geometry using ArcMap.
NULL geometries may be present in a feature class for a variety of reasons, such as when an organization needs to spatially enable a business table. Once this has been done, all the current records contain NULL geometry.
For example, a business table called ROADS was created with a NAME attribute. The business table was then spatially enabled using the 'sdelayer -o add' command.
The resulting business table contains the following records:
Code:
NAME SHAPE OBJECTID
SONORA 1
VINEDO 2
MAR VISTA 3
CONNAUGHT 4
If the geometry uses a native spatial type, the geometry can also be updated using SQL. But, if the feature class utilizes the SDEBINARY type, the geometry must be updated using ArcMap.
ArcMAP 8.x/9.x:
1. Add the Feature Class to ArcMap and start a versioned or non-versioned edit session.
2. Right-click the Feature Class and open the attribute table. Highlight a record with NULL geometry by clicking the little gray box to the left of the desired record.
If a record is not highlighted in the attribute table, the newly digitized feature is associated with a new record, not to an existing record.
3. On the Editor toolbar, select the 'Modify Feature' from the Task drop-down list. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000009128/00N39000003LL2C-0EM39000000wd0W.png)
4. Click the Sketch tool on the Editor toolbar and digitize the new feature.
This adds the geometry to the highlighted record.
5. Save the edits.
ArcMAP 10.x:
2. Right-click the Feature Class and open the attribute table. Highlight a record with NULL geometry, by clicking the little gray box to the left of the desired record.
3. On the Advanced Editing toolbar, click the 'Replace Geometry Tool' and digitize a new feature. This adds the geometry to the highlighted record. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000009128/00N39000003LL2C-0EM39000000wd0Y.png)
4. Save the edits.
Article ID: 000009128
Get help from ArcGIS experts
Start chatting now
