ERROR
Note: This article pertains to ArcGIS versions 8.x and 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Note: ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed.
When attempting to load a feature class into ArcSDE using ArcCatalog, the following error appears:
Error: Underlying DBMS error. ORA-00001 Unique Constraint Violated
Deleting an ArcSDE layer with the sdetable administrator command may leave detached entries in some ArcObjects-maintained metadata tables.
For example, a feature class of the same name previously loaded into ArcSDE using ArcCatalog, but deleted with the ArcSDE commands 'sdelayer -o delete' and 'sdetable -o delete' will produce this error.
Clean up the detached entries in the metadata tables and reload the data.
Article ID:000006235
Get help from ArcGIS experts
Download the Esri Support App
