PROBLEM
Unable to view labels enabled for hosted feature services in the Collector for ArcGIS application for Android and iOS
First Published: May 5, 2016
Last Published: July 21, 2025
Labels enabled for a hosted feature service using the Create Labels option in ArcGIS Online do not display when the same hosted feature service is accessed in the Collector for ArcGIS application for Android and iOS.
The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
Cause
This is a known limit.
Solution or Workaround
To view labels in the Collector for ArcGIS application, label the map in ArcMap instead of ArcGIS Online.
  1. In ArcMap, add labels to the map and publish the map as a tiling service by following the instructions in the ArcGIS Online Help: Publish tiles document.
  2. In ArcGIS Online, add the entire map service with the URL ending in </MapServer> to a blank web map.
  3. Add the feature service in addition to the map service. Do not configure the labels in ArcGIS Online.
  4. Save the web map and open it in the Collector for ArcGIS application.
If duplicate labels are present in the tiled map service, refer to the Esri KB article, Problem: Duplicate labels are present for tiled or cached map services in ArcGIS Online
Article ID: 000012244
Software:
  • ArcGIS Collector
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
