BUG
When using Direct Connect on Solaris or Linux, ArcGIS Server does not connect successfully.
Warning:
ArcGIS Server 9.2 is unable to direct connect to Oracle on Solaris. This is a limitation of 32-bit library availability on Solaris. This Article is for 9.1 and 9.0.1 versions.
This is a known issue in the ArcGIS Server installation; it applies the wrong name to a file that contains the direct connect resources.
Code:
SDEHOME=<ArcGIS Directory>;export SDEHOME
ORACLE_HOME=<Oracle Client Directory Location>;export ORACLE_HOME
LD_LIBRARY_PATH=${ORACLE_HOME}/lib:${LD_LIBRARY_PATH};export LD_LIBRARY_PATH
Code:
SDEHOME=/rapid1/ags91/arcgis;export SDEHOME
ORACLE_HOME=/rapid1/ora92/app/oracle/product/9.2.0;export ORACLE_HOME
Code:
ln -s ./bin lib
Code:
ls -al lib
Code:
lrwxrwxrwx 1 root other 5 Sep 23 22:45 lib -> ./bin
Code:
stopserver
mwadm stop
mwadm start
startserver
Article ID:000008134
Get help from ArcGIS experts
Download the Esri Support App
