BUG
Unable to run ArcGIS Data Store command utilities on servers with a non-English locale
First Published: May 5, 2016
Last Published: February 24, 2021
The following error is returned when running ArcGIS Data Store command utilities on a Windows server with non-English locale:
Current user does not have permission to perform this task. Please retry as the data store owner or Windows Administrator. If you are already member of Windows Administrators group, please try "Run as Administrator"."
This error occurs even when command window is run as administrator and logged in to the server as a Windows administrator.
Cause
This is a known issue at version 10.3 that was corrected in ArcGIS Server 10.3.1.
ArcGIS Data Store command utilities can only be run by accounts that are members of the Windows group 'Administrators'. This folder has a different name in most other locales. Since ArcGIS Data Store fails to find the Administrators group, the command utilities cannot be run.
Workaround
Create a group named 'Administrators' on the ArcGIS Data Store server, and add the login that runs the command utilities to this group.
    Article ID: 000012270
    Software:
    • ArcGIS Data Store
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
