PROBLEM
Unable to rotate features after programmatically selecting them
First Published: May 5, 2016
Selecting features in an edit session using the Select Features Tool or the Edit Tool activates the Rotate Tool on the Editor Toolbar, enabling the rotation of selected features. When the selection is made programmatically within an edit session the Rotate Tool activates, but features fail to rotate.
Cause
The ISelectionEvents::SelectionChanged event must be fired before the rotate tool is fully activated. The editor relies on the SelectionChanged event to union feature selection geometries, and set the selection anchor. If this event is not physically fired there will be no unioned geometry to rotate and there will not be an anchor location.
Solution or Workaround
The following code sample demonstrates how to fire the ISelectionEvents::SelectionChanged event.
Code:
Sub SelectionChanged()
Dim pDoc As IMxDocument
Dim pMap As IMap
Dim pLayer As IFeatureLayer
Dim pFc As IFeatureClass
Dim pSelSet As ISelectionSet
Dim pFSel As IFeatureSelection
Dim pSelEvents As ISelectionEvents
Set pDoc = ThisDocument
Set pMap = pDoc.FocusMap
Set pLayer = pMap.Layer(0)
Set pFc = pLayer.FeatureClass
'Get the selection set
Set pSelSet = pFc.Select(Nothing, 1, 1, Nothing)
'Update the layer with the seletion set
Set pFSel = pLayer
Set pFSel.SelectionSet = pSelSet
'Fire SelectionChanged event
Set pSelEvents = pMap
pSelEvents.SelectionChanged
'Refresh
pDoc.ActiveView.Refresh
End Sub
    Article ID: 000007130
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
