PROBLEM
Unable to remove ArcGIS Online or ArcGIS Enterprise portal connections in ArcGIS Pro
Last Published: October 24, 2024
This article provides the steps to address some common issues that may be encountered with portal connections in ArcGIS Pro.
Inability to set Portal Connection as Active
When there are multiple portal connections in ArcGIS Pro, it may not be possible to designate a preferred portal connection as Active if the 'Set as Active Portal' option is grayed out, as shown in the next image.
option is inactive
The Remove Portal Connection option is grayed out
In the image above, the option to Remove Portal Connection may also be grayed out.
  1. Open ArcGIS Pro and click Settings.
  2. In the navigation pane, click Portals.
  3. Click the three dots next to the portal URL to remove.
  4. Note that the Remove Portal Connection option is inactivated.
The ArcGIS Pro Profile Access feature experiences a looping issue during the Refresh process
When opening a new project in ArcGIS Pro, in the Sign-in Status field at the top right-hand side of the project window, the profile keeps refreshing.
Portal displays "Not signed in" upon logging into ArcGIS Pro
Users are required to click the Refresh button to sign in each time, despite already being logged into the portal. To do this:
  1. Navigate to ArcGIS Pro > Settings > Portals.
  2. Click the three dots next to the portal URL to access, and select Sign in. Click Refresh.
Solution or Workaround
Before following these steps, make sure you have administrative privileges on the computer.
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions. Therefore, use caution and proceed at your own risk.
The AuthorizationPortal registry key ensures that Pro uses this URL as the default sign-in page upon launch.
  1. Exit ArcGIS Pro if it is running.
  2. Open the Windows Registry Editor.
  3. Navigate to the following node:
Computer\HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGIS Online for Pro\SignIn
  1. Double-click the (Default) key.
  2. In the Edit String dialog, under Value data, enter the URL of the ArcGIS Online/ArcGIS Enterprise Organization and click OK. For example:
URL Examples:
    • For ArcGIS Online:
https://testingagol.maps.arcgis.com/
    • For ArcGIS Enterprise:
https://DNS/webadaptorname
  1. Repeat this change for the AuthorizationPortal key.
  2. Navigate to the ArcGIS Online for Pro > Portals node.
  3. Double-click the AuthorizationPortal key.
  4. Repeat Step 5 above to edit the following keys:
    • (Default)
    • URL0
  5. Close the Registry Editor.
If you are unable to remove 'Portal Connections' in any of the scenarios mentioned above, please follow the steps below to remove the URLs from the Windows Registry:
  1. Go to the following registry node:
Computer\HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGIS Online For Pro\SignIn\
  1. Right-click the URL under the SignIn folder tree and click Delete. Similarly, you can remove other URLs.
Article ID: 000033761
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
