PROBLEM
Users are unable to register a table in a feature class with a geodatabase.
This occurs when the table has multiple incrementing columns including an ObjectID column.
The ObjectID column, which is an incrementing column, is already created by ArcGIS when a feature class is registered in a geodatabase. A geodatabase requires the ObjectID field to be the incrementing field to allow the table to be registered.
The existence of multiple incrementing columns requires customization, as the delta tables must be synchronized.
Article ID: 000012556
Get help from ArcGIS experts
Download the Esri Support App
