PROBLEM
Unable to modify the nullable property of a hosted feature service from the REST endpoint
First Published: January 11, 2017
Last Published: July 9, 2026
In some instances, when attempting to use the Update Definition operation to change the "nullable" property of a field in a hosted feature service, the changes appear to be successful but then revert back to the original value.   For example, after changing the nullable property of a field from a value of true to a value of false and then clicking Update Layer Definition, a successful message of "Updated Feature Service Layer" is returned. However after checking the service definition, the changes made to the field are not applied to the hosted feature service and the original value remains.
This is the same for any feature class in ArcMap when trying to alter the Nullable property of a field. When attempting to change one of the fields of feature class that has already been created, from nullable: true to nullable: false, the following error is returned:
Error:
Alter Field Nullable Failed: Unable to alter the field's Nullable property.
The table or feature class is not empty.
Cause
This issue occurs because there may already be null values present in the field for existing features. It is not recommended to edit the nullable property once the feature class or the hosted feature service has been created. Editing may cause issues with the data or an error may be returned.
Solution or Workaround
Republish or overwrite the hosted feature service after making changes to the Nullable property of a field from ArcGIS for Desktop or ArcGIS Pro.
The only way to create a non-nullable field is to specify the property when creating the feature class (or when creating a new field in an existing feature class).
Article ID: 000013994
Software:
  • ArcMap
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
