PROBLEM
The Merge tool combines multiple input datasets into a single output dataset. In some instances, merging feature classes using the Merge tool fails and the following error is returned.
Error: The spatial index grid size is invalid.
This error usually indicates that there are inconsistencies in the spatial index grid values of the feature classes to be merged.
To resolve this issue, recalculate the spatial index of the feature classes before merging. To do this in ArcMap, follow the instructions provided below.
Note: Alternatively, use the Dissolve tool to merge the feature classes, but do not select any fields to dissolve. For more information, refer to ArcMap: Dissolve.
Article ID: 000017674
Get help from ArcGIS experts
Start chatting now
