PROBLEM
The ArcGIS Viewer for Flex Application Builder provides a Locator widget (geocoding widget) that finds a location on the displayed map content in the map viewer by entering an address or longitude and latitude coordinate values.
In some cases, the Locator widget can find the first location; however, when searching for the next location, no result is returned unless the browser is refreshed.
This issue occurs if the Search Current Extent option is enabled. After searching for the first location, the extent of the map changes to a particular location. Therefore when searching for another location, the location cannot be found because the location is out of the current extent.
Get help from ArcGIS experts
Download the Esri Support App
