PROBLEM
Unable to edit data in related tables with the Attribute Editor in ArcMap
First Published: May 5, 2016
Cannot edit data in the related table using the Attribute Editor after setting up a relate in ArcMap.
Cause
Data with relates cannot be edited using the Attribute Editor.
Solution or Workaround
There are two possible solutions.
  • If the data belongs to the same geodatabase, create a relationship class.
    For more information on creating relationship classes, see ArcGIS Desktop Help > Contents > Working with geodatabases > Defining relationship classes.
    Relationship Classes can only be created with ArcEditor and ArcInfo licenses.
  • Select a record in the Table Window. Find and update related records by clicking Options > Related Tables in the Table Window. This command will open the related table if it is added to ArcMap and will allow for selection of records in related tables.
    [O-Image] Image of ArcMap Table Window Options
Article ID: 000002963
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
