ERROR
When trying to create a survey, the following message appears:
Unable to create a new survey. Create Service error Failed to create the service ‘Hosted/survey123_70d687555a8c472888b09944496f9e5d.FeatureServer’.
The logs display the following messages:
The problem has been observed on the following versions:
Environment:
The ArcGIS Server directories and config-store are located on a network drive, in a folder that is hidden or whose name contains a special character, such as ‘$’.
According to Esri documentation, ArcGIS Server does not support shared network directories that are hidden or use special characters.
In this example, the directory settings for \age\arcgisenterprise$, which contained the entire ArcGIS Server configuration must be modified by the IT Administrator so that the folder \age\arcgisenterprise is no longer hidden and no longer includes the special character '$' in its name.
Article ID: 000037861
Get help from ArcGIS experts
Start chatting now
