PROBLEM
Unable to copy and paste the data fame in ArcMap
First Published: October 17, 2016
ArcMap fails to execute the copy and paste commands while attempting to copy and paste the data frame in ArcMap version 10.3 and later.
Cause
This issue is a known limitation for ArcMap 10.3 and later versions.
Solution or Workaround
Insert a new data frame, and copy and paste the layers in the new data frame.
  1. In the ArcMap main menu, click Insert > Data Frame to add a new data frame.
    An image that shows how to insert a new data frame.
  2. Press the Ctrl key, and select the desired layers. Right-click the selected layers, and click Copy.
    An image of copying the selected layers.
  3. Right-click the new data frame, and click Paste Layer(s).
    An image of pasting the selected layers in the new data frame.
Article ID: 000014373
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
