ERROR
The following notice is returned when trying to configure ArcGIS Online's Utility Services with ArcGIS Enterprise.
Notice: Unable to communicate with ArcGIS Online. This feature requires external access to ArcGIS Online and cannot be used in a disconnected environment
The Portal for ArcGIS environment has a forward proxy configured, but the system properties in the Portal Administrator Directory are not configured as per the Configure your portal to use a forward proxy server documentation. This can also be confirmed by tracking developer's tool requests where:
https://proxy.domain.com/portal/sharing/proxy?https://www.arcgis.com/sharing/rest/portals/self?f=jsonfails with the error:
net::ERR_ABORTED
The incorrect port was specified for the forward proxy in the Portal system properties. Also, an inappropriate WebContextURL was included. The below modifications can be made to fix this issue:
Article ID: 000024432
Get help from ArcGIS experts
Download the Esri Support App
