PROBLEM
Unable to change capitalization when editing fields in ArcGIS Pro
Last Published: April 26, 2020
When changing field names in ArcGIS Pro, the changes are not saved if capitalization is the only change made.
EXAMPLE:
Initial field name: fieldone
Desired field name: FieldOne
Cause
A geodatabase does not recognize the difference between case type. Although there is a difference between 'FeatureLayer' and 'FEATURELAYER', it is read the same way in the table.
Solution or Workaround
When making capitalization changes in field names in ArcGIS Pro, an additional character change needs to be made for capitalization to be maintained. The pattern required to resolve this is outlined below:
  1. In the Fields View in ArcGIS Pro, change the field name from 'fieldone' to 'Field_One'
  2. Save the changes
  3. Change the field to 'FieldOne'
  4. Save the changes
Article ID: 000012693
Software:
  • ArcGIS Pro 1 x
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
