PROBLEM
Calculating statistics or building pyramids on an SDE raster dataset stored in a SQL Server 2005 database results in a failure of the geoprocessing tool or a crash of the ArcGIS application. If the process was initiated in the SDE command line, the process does not complete.
This behavior occurs when SQL Server 2005 does not have Service Pack 2 installed, which is a requirement for SDE at 9.3 (see the System Requirements page). To determine what build of SQL Server is currently installed, review the corresponding Microsoft article in the Related Information section below.
Article ID:000010325
Get help from ArcGIS experts
Download the Esri Support App
