PROBLEM
Unable to add a hosted imagery layer to ArcMap
Last Published: October 27, 2021
There is a limitation on ArcMap’s authentication for hosted imagery layers in an ArcGIS Online organization. If a user has signed into ArcGIS Online in ArcMap and is attempting to Add Data by searching for the item in ArcGIS Online, an extra ArcGIS Online dialog box displays that is not intended, and even if the user supplies the credentials again, it does not work.
Cause
This is unlikely to be fixed since Esri is no longer releasing ArcMap.
Solution or Workaround
The workaround to add a dynamic imagery layer to ArcMap is to use the Make Image Server Layer tool with the image service URL and a token. For example: https://iservices.arcgis.com/gUR1YWXNyLOlL4Ys/arcgis/rest/services/release93_test1_di/ImageServer?token=<token>
The token can be obtained using https://developers.arcgis.com/rest/users-groups-and-items/generate-token.htm or from the URL when viewing the REST URL of the hosted imagery layer.
Example:
arcpy.MakeImageServerLayer_management(in_image_service="https://iservices.arcgis.com/gUR1YWXNyLOlL4Ys/arcgis/rest/services/release93_test1_di/ImageServer?token=<generated token>", out_imageserver_layer="online_is_Layer")
Article ID: 000026687
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
