ERROR
The ArcIMS Application Server fails to start properly. When debug logging is turned on, the Application Server debug log file has the following error message:
"UIFONT element could not be loaded from the catalog"
The UIFONT sub-element is missing from the ENVIRONMENT element in your map configuration file (*.axl).
This error occurs the first time after you restart ArcIMS after adding a service without the UIFONT element.
Warning:
This step is very important, if you miss a configuration file here and in step 2, you may have to redo all the steps again.
Code:
<ENVIRONMENT>
<LOCALE country="US" language="en" variant="" />
<UIFONT color="0,0,0" name="dialog" size="12" style="regular" />
<SCREEN dpi="71" />
</ENVIRONMENT>
On Windows your ArcIMSSite.sez file is usually in the "...\ArcGIS\ArcIMS\AppServer" directory
On UNIX and Linux your ArcIMSSite.sez file is usually in the ".../aims40exe/Middleware/Application_Server" directory
Article ID:000005396
Get help from ArcGIS experts
Download the Esri Support App
