HOW TO
Instructions provided describe the steps for turning off MapTips transparency in ArcReader, using the ArcReader Configuration tool. This prevents the tip from becoming transparent when hovering over a feature that has defined MapTips.
ArcReader Configuration Properties - View tab
To apply these changes to multiple machines, copy and paste the ArcReader.art template file to each machine in the following directory before using ArcReader.
C:\Documents and Settings\userprofile\Application Data\ESRI\ArcReader\Templates
ArcGIS versions 9.2 and 9.3 embed the settings made to the ArcReader template in the Publisher Settings on the ArcReader tab. This allows the settings to be stored in the published map, so that they are available in ArcReader standalone.
Article ID:000008428
Get help from ArcGIS experts
Download the Esri Support App
