HOW TO
Instructions provided describe the steps for turning off MapTips transparency in ArcReader using the ArcReader Configuration tool. This prevents the tip from becoming transparent when hovering over a feature that has defined MapTips.
To apply these changes to multiple machines, copy and paste the ArcReader.art template file to each machine in one of the following directories (depending on the operating system used) before using ArcReader.
• C:\Documents and Settings\userprofile\Application Data\ESRI\ArcReader\Templates
• C:\Users\userprofile\AppData\Roaming\ESRI\ArcReader\Templates
The settings made to the ArcReader template can be embedded in the Publisher Settings on the ArcReader tab, which allows the settings to be stored in the published map.
Article ID:000011438
Get help from ArcGIS experts
Download the Esri Support App
