PROBLEM
Tools grayed out in the Oriented Imagery Viewer
First Published: March 28, 2026
Last Published: March 28, 2026
Sometimes, not all of the tools will be available in the Oriented Imagery Viewer - some will be inactivated (grayed out). Please see the following information to understand why some tools may not be available.
Solution or Workaround
Image Gallery
Image gallery only supports the image formats that are internally tiled, such as MRF or COG. It does not support JPEG images (not tiled) and MRF and COG formats without the file extension .mrf or .tif. The images should be available in publicly accessible cloud storage or as feature attachments (.tif only). If the Image gallery is disabled, the current image in the oriented imagery viewer is not internally tiled or does not have the required file extension. See: View oriented imagery layers
Image Enhancement
Image enhancements are not supported for 360-degree images. See the Utilities section of the previous reference.
Image Measurement
The Image measurement tool is enabled only if the Orientation Accuracy property is defined for the oriented imagery layer, as stated in  Work with the oriented imagery viewer.
Article ID: 000036509
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
