ERROR
Too many unique values
Error Message
When attempting a unique values classification on a DBTheme, the following warning message will appear:
"Too many unique values"
As a result, not all features display in the view.
Cause
The SDE configuration.
Solution or Workaround
The MAXDISTINCT configuration parameter specifies the maximum number of values that can be used in an unique query on an SDE layer. In ArcView GIS, this value determines the maximum number of unique values that can appear in a DBTheme legend.
Follow the steps given below:
  1. Change the MAXDISTINCT parameter's value in the giomgr.defs file on the SDE server to suit your classification needs.
  2. Stop the SDE service.
  3. Restart the service to get the parameter changed to take affect.
    Changing this value may increase processing time.
  4. If using Direct Connect, add the following line to a new text file
    Code:
    MAXDISTINCT <value>
    and Save As giomgr.defs in the AVHOME/DConnect/etc directory.
Article ID:000005271
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
