HOW TO
In the Esri 2013 Data Update for Business Analyst Desktop and Server 10.2, a new source of business data was implemented. The 2013 business locations data now come from Dun & Bradstreet (D&B). In prior versions, the source of the business data was Infogroup. To support the transition from Infogroup to D&B, this article explains how to continue to use the 2012 Infogroup business locations data, if preferred, after installing the Esri US 2013 Data Update.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011896/00N39000003LL2C-0EM39000000wdRa.png)
If the Esri USA 2012 option is not available in the drop-down menu, the 2012 dataset has not been installed. To install it, locate the 2012 install media or log into the Esri Customer Care Portal, switch to "all Releases," and then select "Esri Business Analyst 10.2 for Desktop."
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011896/00N39000003LL2C-0EM39000000wdRi.png)
Article ID: 000011896
Get help from ArcGIS experts
Start chatting now
