HOW TO
In ArcGIS Pro, when labeling numeric features with the option to Show thousands separators activated on the data, the separators do not automatically appear in labels.
In ArcGIS Pro, the default language for label expressions is Arcade and when using Arcade, field formatting on the layer is not applied to the labels. Arcade formatting methods are required.
There are two methods to add thousands separators to labels in ArcGIS Pro:
Text($feature.field_name, '#,###')
Note: The label now displays the thousands separators. See the Related Information section for more information on Arcade functions.
Either of these methods can be used in ArcGIS Pro. However, the advantage of using Arcade is that if publishing your layers to the web, the expression is honored and the thousands separators are maintained in your web map and app labels. This is not the case when using one of the other labeling languages.
Article ID:000016672
Get help from ArcGIS experts
Download the Esri Support App
