ERROR
When using an ArcIMS Image Service in the .Net version of the Web Mapping Application, the following error displays:
"There was an error reading the SERVICE_INFO response".
There is likely an invalid attribute value in the map configuration file. The error message may display even if the service works correctly in other clients. The .Net ADF is much more strict when parsing ArcXML than the Java ADF, ArcMap, or the HTML Viewer. Therefore, it is possible for services to run correctly everywhere except with .Net.
Code:
CHARTSYMBOL width
HASHLINESYMBOL linethickness, tickthickness, width
SCALEBAR barwidth
SHIELDSYMBOL minsize
SIMPLELINESYMBOL width
SIMPLEMARKERSYMBOL width
SIMPLEPOLYGONSYMBOL boundarywidth
Code:
<SIMPLELINESYMBOL width="1.5" color="255,0,0" />
Code:
<SIMPLELINESYMBOL width="1" color="255,0,0" />
Code:
<MAPUNITS units="Feet"/>
Code:
<MAPUNITS units="feet"/>
Article ID:000009655
Get help from ArcGIS experts
Download the Esri Support App
