ERROR
The version could not be reconciled. Underlying DBMS error
Last Published: January 4, 2021
Error Message
Reconciling a secondary version against its primary version returns the following error:
Error:
Violation of UNIQUE KEY constraint 'sde_logfiles_uk2'.
Cannot insert duplicate key in object 'SDE_logfiles'.
This article pertains to ArcGIS versions 8.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands, and geoprocessing tools.
Cause
The Permission property on the primary version is set to Protected.
Solution or Workaround
Change the primary version Permission property to Public.
    Article ID: 000007184
    Software:
    • ArcMap 8 x
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
