ERROR
The following error message occurs after successfully reconciling a version with default and attempting to post:
"The version could not be posted. Insufficient permissions"
1) The geodatabase has data that is registered with the option to move edits to base,
2) edits have been performed by other users in the same version on the above referenced data that is registered with move to base, and
3) the user currently performing the post does not have full privileges on the above referenced data that is registered with move to base.
Since the post is on the entire geodatabase and not restricted to only the data the current user has edited, an attempt is being made to post all the changes for that version, regardless of who edited the data, to default. Data registered with the move to base option need to have their edits moved to the base state, and the current user does not have the required permission.
The sde_<sde service>.log file reports that the user lacks sufficient rights to save to base state.
Article ID: 000009480
Get help from ArcGIS experts
Download the Esri Support App
